766 power steering quit
sotxbill
08-22-2005 17:47:56
after setting up for a spell.. finally replaced the battery and got the 766 running.. but the lift and hydraulics works but NO power steering... is there a priority valve or diverter valve or something else to check? thanks.. bill
Curt Cooke
08-23-2005 11:34:33
 Re: 766 power steering quit in reply to sotxbill, 08-22-2005 17:47:56
My 806 would do the same thing on occasion. After getting over the panic, I found the filter was routinely plugged up. Cleaned the screen, replaced the filter, ran the air out and all was fine.
Allan in NE
08-22-2005 18:31:52
Wrong system, Bill.
The steering, brakes and T/A work off the front pump, not the rear, so your lift and remotes will work independently of the other stuff.
Front pump priority is: steering, brakes, T/A and lube. If you're missin' 'em all, probably got front pump troubles.
Allan
