Putting a 300 or 350 engine in a H ???
jugger
08-22-2005 18:20:43
I have a H farmall i would like to get more power out of. A friend told me he knew a guy that put a engine from a 300 or 350 in a H and it made a world of difference. I was wondering if anybody knew anything about that and could explain what needs to be done or modified to make this work. Im very interested in this engine swap
Thank you
ejr-IA.
08-23-2005 08:35:49
 Re: Putting a 300 or 350 engine in a H ??? in reply to jugger, 08-22-2005 18:20:43
I put in a 350lp power unit engine in mine changsd it to gas with m carb and a MW govener.
FarmerSid
08-23-2005 04:54:42
I put a 350U engine in my 51' H. Bolts right up no problem. Make sure you use the H flywheel, clutch and pressure plate. Try and get the manifold and carb from the 300 or 350 as well.
Chers!
Sid
Allan in NE
08-22-2005 18:35:40
Jugger,
Why not just drop in the pop up pistons and sleeves? Darn near makes a M outta 'em.
Allan
Jugger
08-22-2005 18:52:16
 Re: Putting a 300 or 350 engine in a H ??? in reply to Allan in NE, 08-22-2005 18:35:40
Where can a guy get the pistons and sleeves???What else could be done maybe some head work?? I would really like to get the power out of it like a M or better...It might be cheaper to go buy another tractor but i love my H and its the right size for me...
thank you
Allan in NE
08-22-2005 19:12:22
 Re: Putting a 300 or 350 engine in a H ??? in reply to Jugger, 08-22-2005 18:52:16
Oh Heck,
Give it a valve job and drop those pop-ups in from any jobber. You ain't a gonna believe the world of difference it makes!
Feels like a totally different outfit.
I used to pull a 6-row bean cutter with my old H in 4th gear. This one struggles with a silly grain drill going up the hills and I was down in 3rd. :>)
Allan
steveormary
08-22-2005 20:31:18
 Re: Putting a 300 or 350 engine in a H ??? in reply to Allan in NE, 08-22-2005 19:12:22
You mabe aint got enuf ampacity in that H.
That the one with the loader on it??
Did you remove the bucket.
Mabe it is the power steering pump pulling it down.
steveormary
Janicholson
08-22-2005 19:07:32
I believe a super H, 300, or 350 cam will also increase power. Check compatibility before committing bucks.
Jim Nicholson
