Price ranges of a W12
EddyJ
08-22-2005 19:18:54
I have the chance to purchase a W12 tractor garage paint job on rubber, straight, complete and running .Would a fair price for this be in the range of 2600.00 to 3000.00 . Trying to decide if this is worth it ( I know they are hard to find). Mostly familar with the 1940's to 50 IH tractors.Thinking on buying to show with my SW4.
Any input appreciated on this subject. Any faults I should look for on this model.
Thanks
ED
Mike Androvich
08-22-2005 19:56:30
 Re: Price ranges of a W12 in reply to EddyJ, 08-22-2005 19:18:54
I would say that it is in the "ball park" on price. If the wheels are not cut downs it would help it also. Fenders are always a problem on W-12 as they have a tendency to rot out at the attachment point to the axle stub. If they are really solid, again a plus. Make sure the air cleaner is in place, as these are very hard to find separately from the tractor.
EddyJ
08-22-2005 20:17:27
 Re: Price ranges of a W12 in reply to Mike Androvich, 08-22-2005 19:56:30
Thanks Mike , Is there a way to tell if the rims are cutdowns from the steel wheels. Eg :( round spoke . or number of spokes Ect)
ED
pgo12
08-23-2005 03:17:54
 Re: Price ranges of a W12 in reply to EddyJ, 08-22-2005 20:17:27
cut downs will be steel wheels that are "cut". they will have the outer steel wheel [rim] cut off and the flat spokes will be welded to rims that are for rubber tires. pg
EddyJ
08-23-2005 07:28:50
 Re: Price ranges of a W12 in reply to pgo12, 08-23-2005 03:17:54
Yes , I know this all the pictures I can find of a W12 look like they have cutdowns on them. Seems the 10-20's model tractors had round spokes when on rubber.The W12 I'm looking at has flat spokes. Does anyone have a picture of a W12 with original rims for rubber? I sure would appreciate it if you could post it.
Thanks ED
Mike Androvich
08-23-2005 13:17:44
 Re: Price ranges of a W12 in reply to EddyJ, 08-23-2005 07:28:50
Original rear rubber wheels for a W-12 were a very heavy cast iron center with the rim basically pressed on the hub. I have never seen a hub without the rim. There were no spokes with this style. The fronts were available in several styles, some spoked like an F-20, some were cast.
Eastsider
08-23-2005 15:21:28
 Re: Price ranges of a W12 in reply to Mike Androvich, 08-23-2005 13:17:44
third party image
Here is a picture from a Fairway 12 model...it has the rims that were described above...Kind of a rare bird, I think. It lives at our heritage association in East Grand Forks, MN.
