Re: Firing order?
old
08-22-2005 20:13:25
Sounds like you have something off. Dist turned wrong or maybe you set up the timing on the exhaust stroke instead of the compression stroke. OR maybe you aren't sure which cylinder is # 1. By the way just in case #1 is the front cylinder closes to the Radiator
