IH 4366 tractor
mheight
08-23-2005 16:25:13
We recently acquired an International 4366 tractor, and don"t have any service manuals for it yet. Can someone tell me how to check the front differential and where the fluid level should be. I found the plug in the top, but can not find any sight glass or dipstick.
The main gearbox in the center of the tractor looks like fluid runs into the top through a hydraulic hose, flushes through the box and exits through the bottom hose.
I found a plug in the top right hand corner of the rear differential. Does this take 90 weight? And should it be filled to the plug like a normal rear end?
Thanks,
Mike
Luke Long
10-24-2005 10:09:24
 Re: IH 4366 tractor in reply to mheight, 08-23-2005 16:25:13
I'm looking for a international 4366 tractor in good working order. From the research I've done these tractor's seem like there built ok. but I'm aware that you don't know alot till you work one. If any one out there know's the good,bad and ugly on these old girl's please let me know, and if you know where there's one for sale that would be great. (I realy need one with 3-point but will consider any. Thank's for the help) sodbuster
Dave in MN
08-23-2005 19:23:29
Just guessing, there probably is a plug about half way down (from top to bottom) on the pumpkin. If oil comes out when plug is removed, you are good to go. Same method is used on semi tractor rear ends.
