Increase Farmall 100 RPM?
Pierre Theriaul
08-23-2005 17:41:31
Hi,
My farmall 100 engine runs with a slow RPM. The throttle rod stops pushing on the carburator arm when I push the throttle stick to more than half position.
I would appreciate tips on how I can adjust it so the carburator increase RPM when I push the throttle stick from the half to maximum.
It seems to require adjustement in a part located in front of the engine but don't know if it is a hard or simple task...
Thanks in advance.
used to be scotty
08-24-2005 05:04:03
 Re: Increase Farmall 100 RPM? in reply to Pierre Theriault, 08-23-2005 17:41:31
Pierre, When the speed contol lever arm on the govenor is all the way forward, your carb throttle adjustment arm should have the carb all the way open. The threaded clevis arm is your adjustment, simply back off the locking nut and adjust the clevis to open the carb all the way. Hope thats clear. Let me know how you make out.
used to be scotty
