Front Weights for 7-Shank Chisel
Jim Allen
08-23-2005 18:35:41
Got a chance to bid on some suitcase weights to fit my 826D. They have them in lots of two. Not sure if they are the 75# or the ones close to 100#. I've got a 3-point chisel plow (JD-100) which I will configure as either a five or 7-shank. How many weights do y'all think I might need? I figured on buying at least two if they are 100 pounders. More if I don't have to bid to the moon.
Nat
08-24-2005 06:44:38
 Re: Front Weights for 7-Shank Chisel in reply to Jim Allen, 08-23-2005 18:35:41
Yep, two ain't gonna make a spit in the ocean's difference. The only reason to have two weights on the front is if you've got no other place to put them...
K.B.-826
08-23-2005 20:15:41
As many as you can get your hands on at a reasonable price! It's gonna take more than 200 pounds. 06, 56, and 26's are very light in the front end.
w gatewood
08-23-2005 19:44:16
you need the full rack of the 100 lb ones
