Order Farmall Cub Parts Online
Cub Hydralic Pump (rebuild)
GNB
08-23-2005 18:49:31
I have ordered a kit to rebuild the touch control pump on my 49 Cub. Just wanted to know if there are any pointers on doing this or odd wear to look for inside the pump, because I take it that the Kit has only the seals and o rings. All I have to go by is a exploded view of the pump. The seals must have went bad because I am getting lots of Hydralic Fluid in my oil and it is a new engine. Thanks in advance.
GNB
Peabody
08-23-2005 20:00:26
 Re: Cub Hydralic Pump (rebuild) in reply to GNB, 08-23-2005 18:49:31
Typically it is the pump drive shaft seal that goes bad that causes fluid leakage into the oil pan. Certainly replace the o rings, also. It is an easy fix, just keep it clean.
Rudi
08-23-2005 19:56:19
GNB:
The best help I can give you is to point you again to the Cub Manual Server at www.cleancomputes.com/Cub/index.html.
The instructions are there.... under Cub Maintenance Manuals and the GSS-1024 under the Blue Ribbon Service Manuals.
