B OR BN
BUBSDAD
08-24-2005 08:02:59
WHAT IS THE DIFFERENCE BETWEEN A B AND BN.
I HAVE ONE WITH A BN ON THE SIDE, BUT IT LOOKS JUST LIKE THE B'S I SEE IN THE BOOKS.
Red Dave
08-24-2005 08:08:58
 Re: B OR BN in reply to BUBSDAD, 08-24-2005 08:02:59
Measure the differential shaft housings. A B's are about 22 inches, a BN's are about 18 inches.
Follow the link below to see where to measure. The picture at the link is of a B.
jostev
08-24-2005 08:07:52
TH B's have an axle on the left side of the shifter and the BN's just go right to the drop down axle drive.
JT
08-24-2005 14:38:37
 Re: B OR BN in reply to jostev, 08-24-2005 08:07:52
All B's have equal lenghth axles, with 4" shorter axles on the BN, the one with no axle on the left and and a long axle on the right side has had a final drive from an A put on the left side. This is a common practice for people wanting a mowing tractor, but don't want it wide. This is a very dangerous tractor with th A final drive, unless you stick on flat ground.
Nat
08-24-2005 12:48:55
Absolutely, positively, incorrect.
You are thinking of an A or Super A. ALL Bs had equal length axles out each side of the differential housing. The BN's axle housings were shorter. The N stood for NARROW.
Red Dave
08-24-2005 08:10:36
Nonsense!
You are just plain wrong.
Dennis in OR
08-24-2005 08:58:33
 Re: B OR BN in reply to Red Dave, 08-24-2005 08:10:36
play nice guys
