Farmall B compression
donwisc
08-24-2005 09:52:00
Checking out B I just picked up. Compression is 90lbs on all 4 cyl. Also put 100lbs air pressure on each cylinder with no leaks thru the carb or exhaust.
question is wether 90lbs is low, appreciate any feedback.
old
08-24-2005 11:44:30
 Re: Farmall B compression in reply to donwisc, 08-24-2005 09:52:00
If its an all fuel B the reading you got would be great. Or it maybe an all fuel with normal B hood etc also.
scotty
08-24-2005 10:29:26
Don, I think 90 lbs is not a bad reading, more importantly is that they are all about the same! Im sure the tractor should run fine with that amount of compression.
scotty
donwisc
08-24-2005 11:01:32
 Re: Farmall B compression in reply to scotty, 08-24-2005 10:29:26
Thanks scotty, the reason I questioned it is I have a 200 also that has tested as high as 150 lbs but the 200 has a much higher comp ratio
