Seeking more plow advice: IH fast hitch ??
Ksfarmmer
08-25-2005 16:29:12
Appreciate all the input you all provided for a plow for my 300 Farmall for a large garden. Didn't have any success at the auction, but I just noticed an upcoming sale bill that has an IH two bottom fast hitch plow. I'm curious of any experience any of you have had with this type of plow. I've used a IH semi-mounted plow and a Case pull type plow and both worked well. The neighbors 3 point JD was a POS that wouldn't go into the ground. Any similar problems with the fast hitch? Thanks
frarmer
08-30-2005 19:09:25
 Re: Seeking more plow advice: IH fast hitch ?? in reply to Ksfarmmer, 08-25-2005 16:29:12
I have a three bottom plow on a 460 with fast hitch - works great.
farmallhal
08-26-2005 15:24:40
Make sure you are getting the right fast prongs which fit your tractor. These two bottom plows were also made for the Super C/200 tractor and had the small prongs. You might have a lot of rework to do if you buy the wrong size prongs.
Scott Medlock
08-26-2005 08:38:01
I have a 3-bottom Fasthitch plow.. Use it on my 300 U
It Just Works...
You should have no problem with a 2-bottom either Fasthitch or 3pt (like a Dearborn or Ford)... They all work well on the 300.
Scott
Don L C
08-25-2005 20:57:37
I have run across fasthith equip. on "PHOTO ADS",
you got to watch it every day or you might try the search box....
migraine
08-25-2005 20:27:25
I have a 2pt. 2 bottom plow for my 340 Farmall with coulters and use it at the annual plow days . Works great. I have another 2 pt. 2 bottom 16 inch for the Farmall 300, Restored like new plows well. Have a 2pt. 2 bottom rollover plow that I just got ,have not used yet but hope next spring to get in the ground, and I just bought a 3 bottom 2 pt for the 560 or 400 that is all ready to go. With the down pressure of the fast hitch you can pretty much make them go where you direct them. Just keep good sharp points on them and they will suck right in. Migraine
