inside diameter of front H M rims
FarmallB
08-25-2005 17:43:27
Im needing to replace tje roms on my Kelly Ryan grain elevator, and nobody has them or anything thast would fit. the inside hole, center hole is1 1/2 and 4 1/4 long. Giving up finding 2, i thought to replace the rims with front tractor rims. these are 13 1/4 thereabouts, buty they could be shorter. Thanks. my e mail is farmall20@sbcglobal.net. Thanks
Nebraska Cowman
08-25-2005 17:58:46
 Re: inside diameter of front H M rims in reply to FarmallB, 08-25-2005 17:43:27
Do you mean your old wheels have a solid center with a small hole for the bearing? could you just weld you centers to some old car wheels?
Janicholson
08-26-2005 11:32:29
 Re: inside diameter of front H M rims in reply to Nebraska Cowman, 08-25-2005 17:58:46
Information is needed.
Here is a guess !
If the hub onto which you want to put a new rim measures 1-1/2 ", and the bolt holes measure 3-1/4 between holes, !!And!! there are 5 lugs. Then you will have no problems finding rims. There are tons of cars with bigger center holes, and four and one half inch bolt circle (same as 3-1/4 between holes . Chrysler, Ford, full size, and many jeeps have them.
Measure the bolt circle (the size of circle that will pass through the lug centers) for example a ford rim might be 14X5.5X5X4-1/2. This is a 14" wheel for 14" tires, with a 5.5 inch rim width (bead to bead), with a five lug pattern on a 5-1/2" bolt circle.
Clear as yellow clay mud. good luck!!
Jim Nicholson
