need help with f-20 restoration
mattd
08-25-2005 20:57:39
i am restoring an f-20 and need help with where to get parts. i need the hood, shudder rod, gaskets, etc. does anyone sell these parts.
also can i slide the motor forward on the frame after removing radiator, etc. to replace the input shaft seal?
and one more thing. this tractor has a Behlen hi speed auxilary on it. is this worth anything. and where could i get seals for it. thanks for any help
R W Wisehart
08-26-2005 06:21:08
 Re: need help with f-20 restoration in reply to mattd, 08-25-2005 20:57:39
I have good used hoods for sale.
F-Dean
08-26-2005 05:23:28
Rice Equipment (814) 226-9200 has a lot of parts and gaskets for f-20s.
Nebraska Cowman
08-26-2005 03:59:35
Take the coupler apart and both yoke pieces come off. there is plenty of room without moving the engine forward. you will have to measure the seal in the Behlen unit and go to a bearing supplier. Yes there are always guys looking for those units if you don't want it. I have some hoods, and other parts. gaskets are not hard to find.
Jonathan Brown
08-26-2005 05:09:45
 Re: need help with f-20 restoration in reply to Nebraska Cowman, 08-26-2005 03:59:35
HEre is a place to get most of the gaskets you will need and other useful parts as well
http://www.thefordsonhouse.com/p-farmall.html#fregular
