Fast hitch to 3 point conversion
Nathan in Texas
08-26-2005 08:47:31
Just wondering how much work it is to switch back and forth from a fast hitch to a 3 point hitch?
I'm looking at a tractor that has a fast hitch plow and disc and I already have a 3 point rotary mower and blade and post hole digger.
Is this a 10 minute job to switch back and forth or an hour long job? I would probably only use the plow and disc once a year and would be using the rotary mower and blade once a month or so.
Thanks for any input.
Nathan
farmall 340
08-26-2005 20:35:51
 Re: Fast hitch to 3 point conversion in reply to Nathan in Texas, 08-26-2005 08:47:31
I think my adapter is made by speedco and its the easiest three point to use its just like a quick hitch. I`ll post a pic in parts and pieces pics.
504
08-26-2005 19:42:25
Nathan,Check out tonystractor.com He has the best adaptors I have seen.
Madmallard.....NY
08-26-2005 09:21:02
I have a two point to three point conversion on two of my IH tractors. It takes me less then five minutes to hook up my three point equipment. Simply pull the drawbar, hook the conversion tongs to your equipment and slide them in place of the drawbar, hook up the toplink and go.
Nathan in Texas
08-26-2005 09:58:01
 Re: Fast hitch to 3 point conversion in reply to Madmallard.....NY, 08-26-2005 09:21:02
Thanks, I was hoping it wouldn't be a major undertaking.
If I get the tractor I will probably be posting more questions on which kit to buy, etc.
Thanks again! Nathan
Geoff NY
08-26-2005 09:18:46
IH made a 3pt conversion that works ok. It would allow you to change from 2pt to 3pt in about as much time as it takes to move the tractor to the equipment.
dhermesc
08-26-2005 09:22:57
 Re: Fast hitch to 3 point conversion in reply to Geoff NY, 08-26-2005 09:18:46
Also depends on the type of 2pt/3pt converter you have. Some get in the way of the PTO.
steveormary
08-26-2005 11:17:38
 Re: Fast hitch to 3 point conversion in reply to dhermesc, 08-26-2005 09:22:57
I had 2pt to 3pt conversion tongs for cat.1 and cat. 2. With cat.1 equipment you may have to use sleeves or bushings on the cat.1 implements. It was no problem to switch from 2pt to 3 pt hitch.
You will need a bracket on the tractor for the top link to connect to.
