oil pan drain on H
KRUSS
08-26-2005 20:35:27
finally got what was formerly my dad's H back to it's rightful home today. i don't think this tractor has ever been shedded in it's life. also has not been run for a few ?? years. it is not seized. however i cannot get the drain plug to budge. should i use heat?? should i remove the oil pan and then deal with it?? i removed the oil filter cannister and the oil there looked not that bad. btw the tractor has excellent tires, workable tin, has potential for restoration. for sentimental reasons i want to do this one right. my pockets are deeper than usual on this one.
El Toro
08-30-2005 05:02:01
 Re: oil pan drain on H in reply to KRUSS, 08-26-2005 20:35:27
Did you ever remove the pan plug on your tractor?
Counter-clockwise was the right direction for removing the plug. Hal
gene (Missouri)
08-27-2005 10:04:26
Big pipe wrench and a new oil plug.
El Toro
08-27-2005 05:35:02
Are you sure you're turning the drain plug in the right direction? You need to turn that plug counter-clockwise and I would use a wrench or socket so you don't round off the plug. I would apply some heat, but with oil in the pan it may not get hot enough. It would be hard to hold the pan once it has been removed from the block.
If a socket will fit the plug, I would use a six point socket and use a long breakdown bar. 3/4
drive if you have one. Even a 3/4 air impact may loosen it. Hal
RustyFarmall
08-27-2005 06:22:39
 Re: oil pan drain on H in reply to El Toro, 08-27-2005 05:35:02
EL-TORO, counter-clockwise will tighten the plug, you turn the plug clock-wise to remove it. Righty tighty, lefty loosey.
El Toro
08-27-2005 07:27:04
 Re: oil pan drain on H in reply to RustyFarmall, 08-27-2005 06:22:39
I guess I'll have say you are right if removing the plug from beneath the tractor. You would pull
the wrench or ratchet toward you too loosen. Hal
El Toro
08-27-2005 06:56:13
Left is to loosen and that's ccw. I would still use my right hand too. Hal
El Toro
08-27-2005 06:49:37
You're wrong, which way do you tighten a bolt, CW
unless you're using left-handed bolts. Hal
Allan in NE
08-27-2005 06:32:49
Rusty!
Read that again. Me thinks you're needing another cup o coffee! :>)
Allan
KRUSS
08-27-2005 07:06:31
 Re: oil pan drain on H in reply to Allan in NE, 08-27-2005 06:32:49
the one thing i am doing is turning the proper direction!! do intend to try an impact wrench, however a socket only fits so well on a square head.
Ron Sorden
08-27-2005 07:15:08
 Re: oil pan drain on H in reply to KRUSS, 08-27-2005 07:06:31
Dosen't sound like the plug is the right (origianl) one.
janicholson
08-27-2005 08:44:27
 Re: oil pan drain on H in reply to Ron Sorden, 08-27-2005 07:15:08
Laying on a creeper looking directly up at the plug, it is CCW. Almost all tool stores and Autoparts stores will have a square socket selection from which to choose.
Lots of luck, and good job getting the unit "home"
JimN
Jonthan Brown
08-29-2005 07:34:59
 Re: oil pan drain on H in reply to janicholson, 08-27-2005 08:44:27
I have found while working on my F-20 that a 12 point socket that is one or two sizes bigger that the nut size will fit pretty well, but if the nut is rusty it will round it quite easily.
