engines that fit IH 606
norgemanwi
08-27-2005 13:56:39
I have a 606 that needs an engine rebuild or motor swap. I was told that 560 and 706 diesel engines are about the same size. I haven't found many listings for a 236D motor, that was standard in my 606. Is it practical to drop in a motor from a 560 or 706? There a some of these models that are being parted out with engines available, since so many more were made.
Thanks.
JImmy King
08-28-2005 04:07:59
 Re: engines that fit IH 606 in reply to norgemanwi, 08-27-2005 13:56:39
The 236 is the eng. the 460 had also, the 281 used the same block but had a longer stroke. The 281 is what the 560, early 706, and 656 had, and will fit in the 606. Unless you want more HP, overhaul is the way I would go then you know what you have.
jossette
08-27-2005 15:03:55
I would rebuild the one I have.. buy some old motor and year later you're doing the same thing.
this way you will know what you have when its all said and done...
