C/Super C fans
leon
08-27-2005 18:39:25
What's the difference between the fans on the C and Super C, or are they identical?
504
08-27-2005 20:00:55
 Re: C/Super C fans in reply to leon, 08-27-2005 18:39:25
New replacments are the same. If you change one on a Super you may have to tweek two of the blades because they will hit the water pump. 504
Wayne Swenson
08-27-2005 18:59:26
Super C had a larger engine and disc brakes; the brake & clutch pedals are curved, not straight like the C.
Dale in Ar.
08-27-2005 18:49:40
From all I've seen the are the same.Tne water pump on the Super C is the only difference as far as the cooling system goes and a larger radiator.
