Farmall H motor mounts
Mac in TX
08-27-2005 20:04:30
Hi, I am new to Farmall and have a question about the front motor mounts on my 1940 Farmall H.
The mounts are two L shaped pieces of metal with rubber glued inbetween. These have a part #51343DA
and was used from 1939 thru 1942, then the part was changed. Of course after 65 years the rubber is shot. My question is does the newer mount 1943
thru 1953 part #9362D have any rubber in it?? If it doesn't have rubber I can fabricate my own. I also noticed in the parts book manual that the newer mounts have a 4" long bolt which must go through the frame rail, mount, and screws into the engine block.
Thanks for and replys. Mac
randy hall
08-28-2005 17:28:57
 Re: Farmall H motor mounts in reply to Mac in TX, 08-27-2005 20:04:30
i believe that i have a pair of the early motor mounts for an 'h'. i would take thirty dollars plus shipping.
John M
08-28-2005 06:53:25
As stated the newer mount is cast,no rubber.BUT if you change to the cast mounts,you will have to change the siderails as well. I just did that on one of my Ms.
kfox
08-27-2005 21:37:43
The newer mounts are cast iron. One of my 41 Hs has the rubber mounts, and one has the cast iron mounts. I think it was a field change from what I've read. ken
