660D wheel weights
Redfan
08-27-2005 20:45:33
I am looking for information on rear wheel weights for a 660D. I'm in Australia and only a few 660's, and no other 60 series at all, came here so the options aren't that big. A picture of the original style of weights would be good so I can see if they compare to any other Inters.Thanks.
Joe Evans
08-28-2005 05:22:42
 Re: 660D wheel weights in reply to Redfan, 08-27-2005 20:45:33
third party image
Redfan: this is a pic of a set of weights I added to my W-9. I had little luck finding an additional correct set, but these weights have the same OD and bolt circle as the original W-9 weights do.
These should be more available: I'm told they fit a 560 Wheatland, 660, 1206, -56, -26, -66 series tractos. They are 136# each.
Redfan
08-28-2005 05:43:58
 Re: 660D wheel weights in reply to Joe Evans, 08-28-2005 05:22:42
Thanks Joe.
From what you're saying I gather the 660 takes the same weights as the 06,56,66 series tractors. If this is correct I'll have no trouble finding weights as there were plenty of these tractors sold here in Australia. Regards, Redfan.
P Backus
08-28-2005 12:37:32
 Re: 660D wheel weights in reply to Redfan, 08-28-2005 05:43:58
The weights that are most often found on 06, 56, and 66 series tractors don"t look like the one in the picture, which doesn"t look like the weights for my 600 either. I"m not saying that they won"t fit, but I don"t think that they were all the same, at least not from the factory.
Paul
SMA in NE
08-28-2005 19:32:20
 Re: 660D wheel weights in reply to P Backus, 08-28-2005 12:37:32
A friend of mine has a 660 that he has restored and it has rear weights on it that came with the tractor. I don"t know if they are IHC weights or aftermarket weights. I will ask him and try to get a picture of the tractor and the weights. They weigh about 500# according to him. He has had them on and off a few times. He took the 660 to a few tractor pulls and just left the weights at home. Wouldn"t be fun to put those on at a pull. He is a big, strong guy (can grab the back axle of his "C" and pick up that side of the tractor). He is built about like his 660.
