O6 serial number
Dale Hicks
08-28-2005 07:43:50
My O6 does not have a serial number tag that I can find.
Casting numbers on the block are 6722-DJ and 2 11 S. THe transmission housing has these numbers: 8002 DD and 2-11 S. 8005 DG is on the platform and 59829 D on the front axle.
Can someone tell me the year it was built? Thanks. DH
CNKS
08-28-2005 19:52:42
 Re: O6 serial number in reply to Dale Hicks, 08-28-2005 07:43:50
You can be pretty well assured that it was assembled in Feb, March, or April of 1949. The casting codes are the date the part was cast, IH usually let them age a while before using them. The other numbers are part numbers.
BIG JOHN
08-28-2005 14:37:35
Serial number plate is located on the left side of the bell housing, unless it has been removed.
El Toro
08-28-2005 08:32:05
I think it was made in 1949. Feb 11, 1949, Hal
