Order Farmall Cub Parts Online
Cub Cadet 682 Hydro..
Don L C
08-28-2005 17:32:17
I looked every place else for information, no luck....I'll try here...I bought a Cub Cadet 682 with hydro. trans. I am in a wheel chair so I couldent look it over as much as I needed to....seller seamed trust worthey....
As it turnrd out the trans/rear end oil runs out almost as fast as you ad it....
It starts and runs fine hydro. seems to work fine slow fast , forward and backs....If I can get it up on my motorsycle lift I can reach it..... do you think it only needs gaskets?
Can any body help me?
Where can I get a service manual?
Thanks a bunch Don S.W.Ohio
Phlogiston
08-28-2005 20:19:08
 Re: Cub Cadet 682 Hydro.. in reply to Don L C, 08-28-2005 17:32:17
Not exactly sure on the 682 Hydros, but if it's like my 127 then you will need a gallon of Hytran (check capacity to make sure) a new rear cover gasket and a new spin on oil filter to complete the change out. IH may have added a drain plug by the 682s but on mine you have to loosen the rear cover and be ready for the flood of old Hy-Tran. Put the gasket back on dry.
Phlogiston.
