Farmall H w/3-pt
JSB
08-29-2005 05:11:06
I have a Farmall H with saginaw 3-pt with a 2-way valve, I have great down pressure but, I find it difficult to bushog or mow on land that is up and down. Is their anything I can do to solve my problem?
Thanks
MM_TX
08-29-2005 06:54:40
 Re: Farmall H w/3-pt in reply to JSB, 08-29-2005 05:11:06
The Saginaw has a float position. Just pull the pins (one on each side) that are in that U channel that the black rubber is on they are at the top of the hitch toward the back just above the top of the cylinders. That will let the arms ride up when they need to.
Nebraska Cowman
08-29-2005 05:16:08
The three point on the mower should not be rigid but allow the rear to float. You can use a piece of chain as a top link to correct this.
Harley
08-29-2005 15:10:18
 Re: Farmall H w/3-pt in reply to Nebraska Cowman, 08-29-2005 05:16:08
Hey MM, it just never ceases to amaze me how a feller can learn something new every single day. I put a new Saginaw on an M about a year and a half ago and after you posted today, I went out and checked mine, and pulled the pins and, tada, now I have a floating three point. I musta been gone the day they went over that subject in the instructions. Thanks for point me straight, Harley
Dick Davis
08-30-2005 02:35:36
 Re: Farmall H w/3-pt in reply to Harley, 08-29-2005 15:10:18
Harley, I never got instructions with my Saginaw. I bought from a vendor at RPRU. What else don't I know about the equipment? Does anyone have any instructions? I would appreciate reading them. Thanks Dick Davis
