White Smoke; Burning rich
Ed Weld
08-29-2005 12:43:14
Hello Folks; I have a Farmall "c" that sat two years without being run. Engine was frozen, but was able to free it and get it running. The problem now is alot of white/grey smoke and smells like it is burning rick. Any thoughts are appreciated. Thanks in advance!!
Kendall
08-31-2005 06:24:47
 Re: White Smoke; Burning rich in reply to Ed Weld, 08-29-2005 12:43:14
White smoke generally means burning oil, black smoke means you're running rich. Since engine was once frozen, I'd guess the rings are no longer seating against the cylinder walls as well as they once did. New rings and honing the cylinder walls should fix you up. Yes, new sleeves would be great, but I stopped an old engine from smoking by doing just this. If you do this, might as well have the head done over while its off. At that time, I suppose you'll know for sure if you need new sleeves or just a quick hone. Good luck.
Thanks Kendall
08-31-2005 16:45:26
 Re: White Smoke; Burning rich in reply to Kendall, 08-31-2005 06:24:47
Thanks Kendall. I will open it up and see what's what!
hanks to All!!!!
08-29-2005 18:15:13
Thank you Folks. Now I know where to begin looking!
Billde
08-29-2005 16:17:49
Dan, do you have anti-freeze in it? If so you should be able to smell it in the exhaust. Does the engine have good compression? There is a good chance you have stuck rings. I would do a compression test if you haven't already. Keep us posted.
Tractor Dan
08-29-2005 15:59:31
i have a H that does the same well at idle it will smoke a little but when you open it up it blows whitish grey smoke i mean a big cloud of it when working it like on the haybine or harrows it dont smoke hardly at all and its depinatly note water or antifreeze couse in the 6 years i have owned it and ran it i have not added a drop of water to the radiator so im looking for an answer myself
Billde
08-29-2005 16:12:32
 Re: White Smoke; Burning rich in reply to Tractor Dan , 08-29-2005 15:59:31
Dan, you could have bad valve guides, or possibly your oil control rings are stuck. Does it have good power? How's the oil consumption?
El Toro
08-29-2005 15:18:22
With engine at idle see if any bubbles are in the radiator. May be a cracked head or blown head gasket. Hal
Mike Van
08-29-2005 15:02:42
You could pressurize the cooling system to see if there is an antifreeze leak. You will have to take the thermostat out, take the sparkplugs out too. Use one of those pumps all the gas stations used to have in place of the radiator cap. If theres a leak, the pressure will drop right off. While it was sitting 2 years, it could have rusted through somewhere. White smoke isn't good.
Dave_Id
08-29-2005 13:31:19
White smoke indicates anti-freeze/water in the combustion chamber. Bad head gasket? Cracked head? Try retorquing the head bolts and see if that takes care of it before replacing the head gasket.
