still trying to get F-20 mag working
Paul G. in Mn
08-29-2005 15:54:56
this is what I have checked and changed out. I checked omms on the coil and came up with 12.43 checked the wire going from the points to the condenser. Changed to different points, changed to different condensor. I cant see any spark in the points and no spark with the cap on and wire hooked up to a spark plug. Any other ideas what I should check? Thanks Paul
Nebraska Cowman
08-29-2005 17:53:13
 Re: still trying to get F-20 mag working in reply to Paul G. in Mn, 08-29-2005 15:54:56
I had one give me fits one time. The condeser wire was shorting when I put the cover on. I like to test run mags on the bench with a small cordless drill.
John M
08-29-2005 17:39:19
Is the magnet "magnetic"? Take off the coil cover, put the magnet back on,with an impact wrench turn the mag,in the right direction, and see if the spark jumps the safety gap,the peice that looks like a broken wire. If you have a spark there then it should fire.The problem with checking it with a plug is the plug has to be grounded to the mag.
El Toro
08-29-2005 17:17:01
Are you sure the mag isn't somehow being grounded
? That's how they're shutdown when stopping the engine. Check any wire connections for touching
the mag internally to ground. The area where you installed the points and condenser. Hal
F-man
08-29-2005 17:13:26
Be sure to check the "basket" that the points mount in. This rotates to advance or retard the spark. Make sure that it is not grounded. It should only be grounded in the fully retarded (ccw) position. The secondary lead-out wire from the coil and condeser also rotates with this and I've seen them break right behind the basket.
Also, be sure you have the magnet on with the IHC logo facing out(to the right as you are looking at the points).
Yugrotcart
08-29-2005 16:25:55
Points set at 13 thou?
Paul G. in Mn
08-29-2005 16:36:08
 Re: still trying to get F-20 mag working in reply to Yugrotcart, 08-29-2005 16:25:55
yes they are
Yugrotcart
08-29-2005 16:42:00
 Re: still trying to get F-20 mag working in reply to Paul G. in Mn, 08-29-2005 16:36:08
Just grasping at straws here, timming marks on the rotor gear lined up?
Paul G. in Mn
08-29-2005 16:45:06
 Re: still trying to get F-20 mag working in reply to Yugrotcart, 08-29-2005 16:42:00
yes I double checked that. It was a working mag before I took it apart to clean it.
Yugrotcart
08-29-2005 16:49:13
 Re: still trying to get F-20 mag working in reply to Paul G. in Mn, 08-29-2005 16:45:06
If this is an H4, you are turning it the right way, I believe CW?
Yugrotcart
08-29-2005 16:50:08
 Re: still trying to get F-20 mag working in reply to Yugrotcart, 08-29-2005 16:49:13
I should say the rotor turning CW ....
Paul Grussing
08-29-2005 16:55:33
 Re: still trying to get F-20 mag working in reply to Yugrotcart, 08-29-2005 16:50:08
Yes I am turning it until it snaps.
