F-20 generator ID needed
JohnG(TX)
08-29-2005 17:54:02
I have a set of accessory brackets used to mount a generator to the frame rail of an F-20. These brackets came without the generator. I had an email with the generator number, but it went with the last hard drive crash. Does any one have a genarator ID for this? It should be a Delco part, and is not the same as the Farmall generator. I can email a photo of the brackets, but if you have a set, you know what I have. Thanks.
JG
Nebraska Cowman
08-30-2005 04:26:37
 Re: F-20 generator ID needed in reply to JohnG(TX), 08-29-2005 17:54:02
since it was an add-on I bet they used a common auto generator, probably Chevrolet
