My H likes to Hunt--Governor question
Eastsider
08-29-2005 18:25:43
Hi all....I have a '41 H and everything works well, except for the governor. When I rev it up quickly, it "hunts" revs up/down quite a bit. If it is under a load, it works perfectly, and gives great power. I ran it on the dynomometer last Saturday for 40 minutes or so to work in the rings. If it runs with no load, it will hunt up and down. If I put a load on it it works great, full throttle response. If I let off the load slowly, it will settle in and keep a good rpm. If I let the load off quickly, it will hunt again. We have set it to the specs in the manuals, replaced the spring, etc... It is an all fuel manifold/head as original and it will put out 28 HP. Does anyone have any suggestions to try? I guess the weights may be sticky, but when we had it all apart, they seemed to be alright.
Mark
26RED
08-30-2005 07:50:51
 Re: My H likes to Hunt--Governor question in reply to Eastsider, 08-29-2005 18:25:43
I had the same problem on our "39 H. The governor linkage didn"t have much slop in it, but that was the culprit. I had to follow the manual to the letter to get it to work right. After, several tries, now it runs smooth and steady with no hunting!
Brad in WI
08-30-2005 02:09:04
I have a Farmall MD that does the same thing. I have the throttle lever running directly to the control lever on the diesel pump(zero slop) I tried a couple of different governor springs and had no change. The weights are all good also. Any help is appreciated. I would adjust the carb. but that won't help much I think. LOL
Brad
Hermit
08-30-2005 10:06:09
 Re: My H likes to Hunt--Governor question in reply to Brad in WI, 08-30-2005 02:09:04
Some of the things I'd check would be water in the fuel filters, dirty injectors and carbon build-up in the combustion chambers. Fixes may be to drain water from fuel filters, add some kind of injector cleaner to the fuel and run the engine under a strong load for an hour or more. Hope this helps.
Brad in WI
08-30-2005 10:57:23
 Re: My H likes to Hunt--Governor question in reply to Hermit, 08-30-2005 10:06:09
I will try that and see if it helps. Thanks a bunch.
Brad
DAR
08-29-2005 20:31:56
My Super M does the same thing. and i have narrowed it down to slop in the yoke, block and pin on top of the govenor shaft. with the slop it can"t select a precise rpm. take off that breather tube on top of the gov. and see what it looks like.
Aberdale Farm
08-29-2005 19:43:12
Trying to adjust the carb, as Hermit said, would be a good place to start.
I had a similar problem on a Farmall C. I ended up adjusting the governor linkage (shortened it a bit) and it took care of it.
If it still hunts, take it 'coon hunting with you! Ha!
Dale
Hermit
08-29-2005 19:11:35
I'd try adjusting the main fuel screw on the carb a little one way or the other.
dhermesc
08-30-2005 07:56:34
 Re: My H likes to Hunt--Governor question in reply to Hermit, 08-29-2005 19:11:35
I agree with Hermit. If that doesn't work you might try cleaning the carb, the governor might be reacting to a sticky gunked up float valve.
Eastsider
08-30-2005 17:57:38
 Re: My H likes to Hunt--Governor question in reply to dhermesc, 08-30-2005 07:56:34
Thanks for the advice....I'll try out some of those ideas. I think it is probably a linkage problem, so will start there I guess.
