806 hyd leak
Farmer Gene (NW
08-30-2005 07:59:08
I have an 806 that is leaking hyd fluid along the torsion rod that the three point implement arms attach to, I know I have to pull the pto to get the rod out but was wondering if any special tools are required to change the "0" rings and bushings? Or any tricks I should know about. Thanks, Gene
Aces
08-30-2005 16:00:23
 Re: 806 hyd leak in reply to Farmer Gene (NW WI), 08-30-2005 07:59:08
Gene If I remember right there are no special tools to do the job, but you will need some kind of bushing driver or puller to replace the bushings. I would think you will need to check and or readjust the hitch after replacing, because the torsion arm will have to come off to get the shaft out.
