Order Farmall Cub Parts Online
1951 Cub transmission trouble.....
Josh Hoffman
08-30-2005 13:47:55
I'm working on my 1951 cub that developed a "whine" in 1st gear...I've got the rear wheels off/ PTO & cover are off, gear-shift lever is off...if you are looking down @ the top of the transmission (like you were on the driver seat), on the left side of the trans case, below the shifter rod, there is a single gear...by rocking the pinion gear fwd & back, I have isolated a "clunking" noise coming from this gear, feeling it, it seems quiet loose w/ "play" in the shaft it rides on...is this my 1st gear "whine"? I'm trying to avoid going too far into a tear down if avoidable. I also noticed a retaining bolt of some type @ the top of the housing for this single gear, could tightening this bolt help me?
Bigdog
08-30-2005 14:03:02
 Re: 1951 Cub transmission trouble..... in reply to Josh Hoffman, 08-30-2005 13:47:55
The gear on the left side by itself is the reverse idler.
Tale a look here and see if this helps you:
http://www.cleancomputes.com/Cub/Cub%20Maintenance%20Manuals/Cub-Transmission%20Details/index.html
Josh Hoffman
08-30-2005 14:00:32
 more..... in reply to Josh Hoffman, 08-30-2005 13:47:55
I guess my question is, how can I trouble shoot my noise problem in 1st gear? Everything seems o.k, no damage to gears, shafts look o.k, no excessive play by manipulating w/ hands, how do I know where to look for the problem or what part to order to fix it? am I on the right track???
