Farmall H didtributor part?
ACIdaho
09-02-2005 13:25:20
Hi, I"m over from the AC forum. I have a AC "B" that has a 1944 Farmall H didributor on it.
I"m looking for the dudt cover that fits between the cap and points (mine is broken).
The ones that I have got on the internet are not even close (physically). My distributor has a 90 deg turn on it and sits vertically.... thanx much, Chuck
RustyFarmall
09-02-2005 15:40:18
 Re: Farmall H didtributor part? in reply to ACIdaho, 09-02-2005 13:25:20
I thought the Allis's used the delco distributer?
ACIdaho
09-02-2005 16:22:47
 Re: Farmall H didtributor part? in reply to RustyFarmall, 09-02-2005 15:40:18
Don't know....my B had a Fairbanks magneto (1949)
upred
09-02-2005 15:22:03
I have a delco on my 48 H, distrib number is
1111411 4G1 HTH Rick,
Bob
09-02-2005 13:44:04
You have an AFTERMARKET distributor, most likely a Delco.
A bunch of outfits sold those as retrofits.
I'll look in my Standard Ignition catalog, and see if they still list any of the dust covers for those and post back later.
Bob
09-03-2005 08:21:58
 Re: Farmall H didtributor part? in reply to Bob, 09-02-2005 13:44:04
The only SIMILAR Delco dustcap I can find in my reference materials is Delco #1900119, Standard ignition #DR-426.
Does the dust cap you need fit INSIDE the top opening of the distributor, or "sandwich" in between the cap and distributor?
The number I've posted sandwiches in between the cap and distributor.
I MAY fit your's, I'll try to do some more research. (I'd hate to see you order one and have it not fit!)
ACIdaho
09-03-2005 13:55:36
 Re: Farmall H didtributor part? in reply to Bob, 09-03-2005 08:21:58
Hi Bob....it is sandwiched between, is alignment keyed with the distributor base. Chuck (has a fiber gasket on the bottom circumfrence of the dust cover
