W-6 Fioble,s?
W-6 Kirk,
09-03-2005 06:31:15
My W-6 is stuck in reverse,
I cant get it out,
a friend said to pull off shift handle,
then alighn the slot,s inside case,
them put the handle back on,and It will be ok from then on,
Another thing,
Do I have to have the clutch pedal all the way
in to shift it?
Im 5'10',& I have the seat all the way forward,
& It,still away,s to push the pedal all the way
in,
Any way to rectify this?
thanks alot, K,C,
BIG JOHN
09-03-2005 18:29:08
 Re: W-6 Fioble,s? in reply to W-6 Kirk,, 09-03-2005 06:31:15
Farmers use to add a piece of 2x4 to the face of the clutch peddle so their young sons could operate the clutch. I've even seen a 4x4 block used.
GOOD LUCK
Haas
09-03-2005 14:31:43
I have an I-6. Somewhere along the way someone cut the tube of the seat support, shortened and rewelded it, making the seat farther forward. Now in my opinion, it is too far forward, but that would be a solution for your seat that is too far back.
