row crop vs wheatland
max adams
09-04-2005 10:48:44
what is the purpose in the wheatland over the row crop? as always thanks!!!
CNKS
09-04-2005 14:10:38
 Re: row crop vs wheatland in reply to max adams , 09-04-2005 10:48:44
The wheatland or standard tractors were used by farmers who did not need mounted implements, examples are farmers on the Great Plains who grew only small grains such as wheat, thus needing only trailing implements. My father in law was that type of farmer, he bought a 656 (not a wheatland type) with no 3-point, because he had no use for mounted implements. He had previously used wheatland-type tractors.
Hugh MacKay
09-04-2005 11:24:34
Max: You'll notice the difference was very little after the days of cabs. I think before the days of cabs farmers liked the standard design that sheltered them from harsh prarrie winds. With smaller diameter and wider rear tires you also got a bit more drawbar hp.
I've talked with guys that actually worked both eastern as well as prarrie soils. They will tell you and I know this to be true 13x38 row crop will give you better traction than 14x30 or 34 in the softer eastern soils. I'm told this is not so on firmer prarrie soils.
