Where Can I get??????
Short Bolt
09-04-2005 11:17:04
Dose any one know where I can purchase good used LP set ups complete for a Farmall 460 and for a Farmall 340 Tractor Would trade the 460 wide front gas for a 460 0r 560 LP tractor if need to I have a nice 706 gas setting in my shop , down for a engine overhaul thinking about conerting it to LP Where can I get all the engine fuel system parts used and the tank and sheet mtal to make it look good? Thanks
Janicholson
09-04-2005 13:37:09
 Re: Where Can I get?????? in reply to Short Bolt, 09-04-2005 11:17:04
Put an ad in the Vintage adds section to the left on this page. Also look at these adds for what you need. Propane is (relitively) cheap right now, but it (my opinion) will also rise sharply as oil remains high. People will use more, and demand will create increasing prices. Drive less, drive a new enough 4cyl car to have fuel injection, and work with what you have. The conversion of a gasoline to run on LP/Propane includes different (rare) heads, dome pistons, and a bunch of plumbing. Making it look and run correctly is way more expensive than either selling what you have and buying a LP factory unit, or living with the fuel prices, and being conservitive. Propane has less energy in it than gasoline, so the per gallon cost must not be directly used. My opinion, from highway vehicles, not tractors, is between 70 and 80% less work/gal with LP. The units do however run for a lot longer without problems, they are clean.
JimN
