Farmall 460-560 WARNING
the tractor vet
09-04-2005 17:07:03
For all of you boys out there with Farmall and Int. 460-560 check your main battery cable from the battery to the starter just got home from repairing a Farmall 460 Gasser that the original Battery cable shorted out on the FUEL TANK and was real close to burning thru and with a half tank of high test things could have shell we say interesting.
Ducknose Bob
09-05-2005 02:45:02
 Re: Farmall 460-560 WARNING in reply to the tractor vet, 09-04-2005 17:07:03
The best I ever seen was the dairy farmer who used baling wire wrapped with electrical tape.
K.B.-826
09-04-2005 19:35:21
Thanks for the warning, tractor vet. I'm always surprized by how neglected the electrical systems and wiring are on these old tractors. I'm sure you've seen just as many as I have where somone's connected two wires just by twisting them together and mabey wrapping a little tape around them. Of course, all of the oil dripping on the wiring makes the tape fall off! I hate it when someone wants me to fix a mess like that without rewiring the whole tractor. If only everyone knew what a disaster waiting to happen bad wiring is!
the tractor vet
09-04-2005 20:36:56
 Re: Farmall 460-560 WARNING in reply to K.B.-826, 09-04-2005 19:35:21
My favort is the extenshion cord and wire nuts to repair bad wireing or just wire nuts . well it took me over four hours but it is done correctly and to color code and correct Ga.
