Wiring help.
dean sahs
09-05-2005 08:29:25
I have a 1966 Towmotor brand lift truck with a International 345 cu. inch motor. It is in good overall condition, except that all the wiring has been removed and I need to replace the basic ignition and starter wiring. Does any one have a sketch or schematic for this, it would be greatly appreciated. Thank You. dean
El Toro
09-05-2005 09:00:15
 Re: Wiring help. in reply to dean sahs, 09-05-2005 08:29:25
Try this toll free number on Tuesday to see if they have a wiring diagram or a new wiring harness
for your Towmotor. The engine was probably used in IH trucks and probably used the same wiring.
If you check with your local IH dealer may be able to help you if they've kept their manuals on trucks that used the 345 engine. BOB M is an electrical engineer that posts on here a lot and most of the wiring diagrams used on these tractor with 12 volts are probably very similar to your engine. You can view his wiring diagrams by
going to this website. I know there should be one close enough that would get your lift running. Hal
http://albums.photo.epson.com/j/ViewPhoto?u=4001561&a=30065733&p=63426275
