15.5 tires on a Farmall
Glenn F.
09-05-2005 21:22:01
Just curious, what was the first Farmall series to come factory with 15.5 X 38 rear wheels? Thanks, Glenn F.
DWV
09-06-2005 05:08:34
 Re: 15.5 tires on a Farmall in reply to Glenn F., 09-05-2005 21:22:01
None comes to mind before the Farmall 450.15.5 X 38 tires were on some of those.
RustyFarmall
09-06-2005 06:31:29
 Re: 15.5 tires on a Farmall in reply to DWV, 09-06-2005 05:08:34
I've seen 15.5X38s on SMTAs, don't know if those were a factory option or installed later. I've also seen that size on a straight M, I'm sure those were installed by the owner.
Dr.EVIL
09-06-2005 08:18:59
 Re: 15.5 tires on a Farmall in reply to RustyFarmall, 09-06-2005 06:31:29
15.5X38's were a new size created by the Tire & Rim Manufacturer's Association in 1954. There is no "Equivalent Size" in the old size ratings. 450 was the first tractor to commonly use the size. And most 560's had them as well. Lot of Super M-TA's & 400's had 13X38's which became 14.9X38's, but 12X38's, now called 13.6's were more common. Seems to be common to put 2-3 sizes larger tires on tractors now.
