Re: 350D not starting
Cotton Picker
09-07-2005 09:36:45
That is correct, I touched the test light to the battery cable on the starter solenoid and the light did not come on.
What does that tell you?
El Toro
09-07-2005 09:59:45
 Re: 350D not starting in reply to Cotton Picker, 09-07-2005 09:36:45
Are you saying there's no voltage on the big battery cable where it connects to the starter?
If that is so, you need to clean all battery connections and where your battery is grounded.
If you have voltage at the big battery cable, short across the solenoid with a screwdriver and see if the engine cranks. Hal
dhermesc
09-07-2005 11:23:49
 Re: 350D not starting in reply to El Toro, 09-07-2005 09:59:45
Agreed, the problem is not your starter button, either one of your cables has burned out or you have lost a contact point.
El Toro
09-07-2005 12:57:37
 Re: 350D not starting in reply to dhermesc, 09-07-2005 11:23:49
I think you should be telling the Cotton Picker
this info. Hal
