Re: 350D not starting
Nat
09-07-2005 13:09:37
I think you're barking up the wrong tree.
If you are not getting voltage at the big fat cable on the starter, it's NOT the starter switch. Touch one end of the tester to the fat cable, and the other to anywhere on the frame. It should read between 12 and 13 Volts, or it should at least light up, depending on what kind of tester you have.
No light, no volts. You can change starter switches until you're blue in the face, and die of old age, and it won't fix the problem.
Cotton Picker
09-07-2005 13:51:12
 Re: 350D not starting in reply to Nat, 09-07-2005 13:09:37
Thanks for all the input, I am printing it out and taking it with me when I work on the tractor.
These tractors are VERY rare in the Mississippi Delta so I am in the dark sometimes. My father ran an IH store for 20 years and had never seen a 350D until we bought this one.
Again, thanks for the input, I will let you know what happens.
CP
EL Toro
09-08-2005 06:08:53
 Re: 350D not starting in reply to Cotton Picker, 09-07-2005 13:51:12
Nat is right on the money on checking for voltage
at the starter on the battery cable at the starter. No voltage present you either have corroded cable ends or corrosion inside the battery spades. If they're crimped I would install a new cable with soldered ends. Hal
