Replacing a TA on 350 FARMALL
bedrock1234
09-07-2005 14:12:17
I am going to replace a defective TA on my 350 FARMALL and need to know if there any pointers I should know. I have an IT manual and find it kind of vauge, I bpught the remanufactured TA from Steel Wheel Ranch as I have read good thing about them.any help would be appriciated. Thanks in advance. Gary
slifnom
09-10-2005 16:10:41
 Re: Replacing a TA on 350 FARMALL in reply to bedrock1234, 09-07-2005 14:12:17
Have you tried adjusting the TA exactly the way the manual states? When I bought my 350 utility the TA did not work. I adjusted it to specs, and a miracle happened! It works again. It really is worth a try.
the tractor vet
09-07-2005 18:35:09
When ya install the T/A becareful as not to roll the ft. seal i have seen this happen tomany times as i have to fix someone else's screw up this weekend on a 400 and make sure that you get the T/a clutch flywheel tight and set the tab or it will come lose.
