806 issues
MTA
09-07-2005 18:17:14
thanks for the help fellas. I went to the imp and they said that the oil gushing out inside the rear end was normal and for lube. He thought that the lack of hyd pressure was a leaky o-ring at the pressure port. Not knowing any better, I pulled the pump, and I have 2 ports. One o-ring was in kinked, but they do not list parts for an 806 with 2 ports going into the rear. Mine is a 64 sn 1923. So now they can't find me the right gasket and I am really thinking that this isn't going to solve anything. Does anyone know of the 2 port system? Or any thoughts on this whole stinking situation? Thanks Mike.
the tractor vet
09-07-2005 18:31:04
 Re: 806 issues in reply to MTA, 09-07-2005 18:17:14
I have no idea of what you are talken about here and i know the 06 seires inside and out the hdy. pump has and in and an out port and reqiures TWO o/rings to mount to the plate and only one o/ring on the high pressure side the mounting gskt. seals the suction side . We can spend all nite on this deal the best and cheepest way to find out what is going on with the hdy system is to get the tractor on a flow rater and see what you have for GPM and pressure on the hitch pump and do the same for the MCV . Then you know if ya need a pump or a releif valve . With out the flow rater you had better have a bottomless check book.
MTA
09-07-2005 18:52:57
 Re: 806 issues in reply to the tractor vet, 09-07-2005 18:31:04
T.V. My checkbook is already sounding hollow, lol. The guys couldn't find a gasket in their books that have 2 holes for ports, yet I showed them the pump cover and I have 2 ports on the tractor. You are correct in that this is going to n&d me to death, and it's gotta heckuva start. If I can get past this gasket/o-ring, and have no luck, I will drive the tractor to town and have it checked w/flowrater. Thx Mike
the tractor vet
09-07-2005 19:02:34
 Re: 806 issues in reply to MTA, 09-07-2005 18:52:57
There is ONLY one gskt. fot that tractor does not matter if it is and International or Farmall . I have had somany of them apart that i can tell you the size of wrench ya need for what bolt your taken out .
MTA
09-07-2005 19:14:54
 Re: 806 issues in reply to the tractor vet, 09-07-2005 19:02:34
T.V. One gasket? What about the other port? I am looking for help and can't believe that there is not another gasket. There are TWO ports going into the rearend of the tractor. The guy up at the imp also had never seen this. thx mike
chadd
09-08-2005 05:03:25
 Re: 806 issues in reply to MTA, 09-07-2005 19:14:54
Do you have a digital camera? Could you take a picture of it so that it would make it easier for us to understand what you have? I myself have never seen the inside of an 06 rear end, so I would have to consult my service manual before even attempting to answer your question. From memory though, I would have to agree with tractor vet, I don't recall there being two ports on the picture in my manual.
