Carb Removal
Elk Farmer
09-08-2005 16:40:15
I have to remove the Exhaust/Intake Manifold from my H. How do you remove the throttle Shaft from the governor.
Thanks.
Elk Farmer
brainerd dave
09-08-2005 16:48:49
 Re: Carb Removal in reply to Elk Farmer, 09-08-2005 16:40:15
Don't. Remove the throttle shaft from the carburetor side instead. When you reinstall, just make sure that the pin on the shaft fits into the slot on the throttle body on the carb.
Elkfarmer
09-08-2005 17:39:57
 Re: Carb Removal in reply to brainerd dave, 09-08-2005 16:48:49
How do get to the Carb shaft. Do you start by removing the two screws?
Thanks
brainerd dave
09-08-2005 17:46:36
 Re: Carb Removal in reply to Elkfarmer, 09-08-2005 17:39:57
Yep, remove the two screws. That's all that is holding the throttle shaft to the carb. If you are going to remove the carb, disconnect the fuel line (shut the fuel off first), disconnect the air intake hose and choke rod. Remove the two nuts holding the carb to the manifold - sometimes the studs screw out instead of the nuts - that's OK, drop the carb and the shaft end should slide right out.
Elk Farmer
09-08-2005 17:53:42
 Re: Carb Removal in reply to brainerd dave, 09-08-2005 17:46:36
Thanks brainerd dave
Elk Farmer
brainerd dave
09-08-2005 17:58:58
 Re: Carb Removal in reply to Elk Farmer, 09-08-2005 17:53:42
Anytime. There's an elk farmer down the road from me I haven't met. If you're in Brainerd and that's you, I'll walk over and give you a hand:)
Elk Farmer
09-09-2005 12:43:38
 Re: Carb Removal in reply to brainerd dave, 09-08-2005 17:58:58
Thanks for the offer.
I live 20 miles West of Ann Arbor MI
