IH 444
Kevin Hood
09-09-2005 16:18:35
I'm thinking about going to look at a 444 diesel. Are these good tractors? What should I be looking for?
Thanks, Kevin
mowr
09-11-2005 18:51:05
 Re: IH 444 in reply to Kevin Hood, 09-09-2005 16:18:35
Be sure the check that you have both the specified free play at the top of the (two-stage) clutch travel AND enough at the bottom of the travel to completely stop the PTO. Good tractors, though clutches were not their strongest point.
MJ in the UK
09-10-2005 02:15:53
Very good little tractos made at Bradford here in the UK. Make sure the Glowplug engine heating systen is OK. There was a post two days ago on this subject 384 glowplug problem and JB2 explaned it very well MJ
Haas
09-09-2005 16:57:08
The 444 followed the 424 and is similar. A very good utility tractor around 40 HP. I once owned a 424 gasoline. On the 424, power steering was an option and I suppose as well was on the 444. The PS would be a definite plus. I did have some problems with the 3 point lift on my 424. The lift got to where it would not stay up or pick up much. A new piston was required for the lift cylinder which is inside the lift unit case under the seat. These tractors have a separate reservoir and do not use the transmission fluid for the hydraulics. A plus is that the older Mahindra tractors are almost direct copies of the 424/444 and many parts interchange. When the lift on my 424 needed repair, a Mahindra piston was used for the repair at about 1/2 the cost of the IH part. I never had much other problems. The tractor was very dependable.
Kevin Hood
09-09-2005 18:47:33
 Re: IH 444 in reply to Haas, 09-09-2005 16:57:08
Thanks for the info!
Kevin
