end play on no 8 plow wheel hubs???
Andy2
09-09-2005 16:51:10
I am fixing up a no 8 plow for an upcoming plowing day. The wheel hubs seem tight but there is about 1/2" end play on each of the front wheels. Is this normal or is should it be tightened like a timpkin bearing? Thanks
RustyFarmall
09-09-2005 18:23:24
 Re: end play on no 8 plow wheel hubs??? in reply to Andy2, 09-09-2005 16:51:10
There is an apparatus inside the hub that will let you tighten things up a bit. Remove the cover and look in there. You may find that the adjustment has already been used up, in which case you will need to fabricate a sort of extra large flat washer to be used as a spacer. You do not want too much excessive slop in the hubs.
