What's the point.???
stan2270
09-09-2005 18:13:25
Hi forum folks! Does anyone have a suggestion for a good 3 point conversion that will work on a "53 SA (not fast hitch)? Thanks in advance for the advice. Stan
Haas
09-10-2005 06:20:40
 Re: What's the point.??? in reply to stan2270, 09-09-2005 18:13:25
You can get a 3 point conversion for your SA from Worksaver. Website is worksaver.com Be aware that the SA with this hitch setup will lift a max of about 500 lbs. Also the lift range is somewhat limited as compared to a modern tractor with 3 point hitch. If you are using pto equipment, there could be some problems due to the offset PTO location, but in my experience most things can be made to work. Don't expect the hitch to work very well with a plow, but it will be ok for a light carryall, small three point disk, dirt scoop, lightweight blade, etc.
