Hydrolic pump
Don Wells
09-10-2005 17:52:11
Yesterday I used my 350 utility to move round bales with no problem. The hydrolic system has some leakes in it so I check and top off on a regular basis, This morning I went to move the rest of the bales and the bale spear would not go up or down. I check the fluid and it was a little low but not bad, I noticed the fluid was white looking like air was beat into it, what does everybody think?
PAULIH300
09-10-2005 18:23:16
 Re: Hydrolic pump in reply to Don Wells, 09-10-2005 17:52:11
What fluid have you been using? Use only premium Hy Tran type.Cheap stuff foams.Could also be a leak in the pump seals.
