Electrical problem
BEAST
09-10-2005 18:30:28
I recently restored a 560. every thing is new. hooked up the new wiring harness and generator starts smoking. There is a constant charge going to generator even when key is shut off. double and triple checked to make sure all wires are hooked up correct. any ideas whats wrong. thank you in advance.
Hermit
09-10-2005 20:20:13
 Re: Electrical problem in reply to BEAST, 09-10-2005 18:30:28
If all the wires to the voltage regulator are properly connected to the right screws, it sounds like the points on the cutout relay in the regulator are welded closed allowing voltage to feed back to the generator.
PAULIH300
09-10-2005 18:36:16
Sounds like a dead short at the generator.
R-cubed
09-11-2005 14:57:03
 Re: Electrical problem in reply to PAULIH300, 09-10-2005 18:36:16
If the new wiring was correct and the cutout worked there wouldn"t be any connection to the generator with the key turned off. That being the case either it is wired wrong or the cutout suddenly went south.
