Lights on an A
holcombwa
09-10-2005 19:51:58
Well, the generator is generatin' like crazy now, so.... how do you get into the lights on the rubber light housings on an "A"? Know the switch is ok and hooked up right so guess no lights because of problem bulb or light fixtures. All help is appreciated.
Stan
gene b
09-11-2005 05:21:12
 Re: Lights on an A in reply to holcombwa, 09-10-2005 19:51:58
probably doesent have a good ground. i would make sure of that first. the rubber can be removed by using a knife around the edge. hard telling when the last time it was opened. bulbs should be 1133 and you can buy them from an auto parts store.
