farmall A problem
upred
09-11-2005 17:45:54
I just replaced a leaking head gasket on my A and now it won't increase or decrease in rpm when the throttle lever is moved. What did I do ??? I torqued the head and set the valves, got it hot and retorqued and reset valves, nothing else was changed. Any Ideas?? Rick
holcombwa
09-12-2005 05:53:47
 Re: farmall A problem in reply to upred, 09-11-2005 17:45:54
Might want to check the governor setup. Mine had similar problem and liberal lubing of governor links and pivots along with adjusting according to the book got it working again. Don't know for sure, but that would be the first place I would check. Good luck.
Stan
W.K.TEDDYBEAR
09-13-2005 07:21:45
 Re: farmall A problem in reply to holcombwa, 09-12-2005 05:53:47
I AGREE CHECK GOVERNOR SETUP AND ALL LINKAGES FOR PROPER CONNECTION
