W6 shifter pin
Yugrotcart
09-11-2005 18:14:13
Friend was driven my W6 today when the transmission locked up, couldn't move the shifter. Turns out the pin that holds the shifter in was wore bad. Got the old pin out and, at least for the time being, replaced the pin with a 7/16 bolt. Should I use something other than a bolt, or an I worrying about nothing.
RustyFarmall
09-11-2005 18:52:06
 Re: W6 shifter pin in reply to Yugrotcart, 09-11-2005 18:14:13
The bolt will be just fine. If you don't look at it you will never know the differance.
Yugrotcart
09-12-2005 13:08:22
 Re: W6 shifter pin in reply to RustyFarmall, 09-11-2005 18:52:06
Thanks Rusty, I won't look at it..... .....
