F-20 valve train assy. problem
Red Mark
09-11-2005 20:38:48
Upon recently reassembling the valve train on my F-20, I have found that the valve cover doesn't seal at the valve cover gasket. The gasket = 0.125" thick and the gap with the cover fully seated minus gasket is 0.15". I suspect I have the wrong stack-up of fasteners from the oil trough up. From the oil trough up I have the spacer, flat washer,lockwasher,nut,then valve cover in that order. Is that correct? Or maybe the gasket is too thin? Thanks for any help
Nebraska Cowman
09-12-2005 03:23:47
 Re: F-20 valve train assy. problem in reply to Red Mark, 09-11-2005 20:38:48
Take out the flat and lock washers. Also a lot of times the top of the cover is smashed down from being overtightened. It should be flat on top.
Red Mark
09-12-2005 15:37:20
 Re: F-20 valve train assy. problem in reply to Nebraska Cowman, 09-12-2005 03:23:47
That should work. I just don't like to have leftover parts, especially lockwashers. With the valve cover nut on, the lower nut can't go anywhere so who needs the lockwasher. Why didn't I think of that? Thanks again Cowman!!!
