2500-A INT POSI-Track Lever or Rear End Lock UP
Jack Henry O
09-12-2005 17:11:06
I need help on my 2500-A I can't get the lever to move up or down,with clutch In or Out. Any suggestions? TX For ANY HELP Jack Henry O
Jack Henry O
02-12-2006 11:03:55
 Re: 2500-A INT POSI-Track Lever or Rear End Lock in reply to Jack Henry O, 09-12-2005 17:11:06
Hey ,Someone out there ought to know something about a Posi-Trac rear end on a INT 2500-A> PPlease help,Even the repair manual doesn"t cover it. TX JACK HENRY O
Nat
09-13-2005 06:22:19
I've got two words for you: PB Blaster
The linkages and/or pivot point on the levers are more than likely rusted up from lack of use.
If not, then it's just like any other internal tractor problem. There's no way to know what's wrong until you take it apart.
